How to .........
Car  A well built VW
Anyone got a guide to fitting dual optics from a 172 onto a normal clio? If so can they post it or pm me
Ive done it Yin, do you need to know anything in particular. I did it a while back but can probably remember most steps.
Just how to make the adaptor wires and is there not something to do with a new fuse aswell All help appreiated
you need a new fuse fitted for the extra bulb... and you need to alter the wiring to seperate the H7 and HB3 bulbs. You can just splice it off the current wire, but make sure you earth it.
i had the lights for my old car but gave up with mine because im a lazy f**k.
/Dan.
i fitted mine without the need for adding a fuse, must have already been there for some unknown reason.
Easy to wire though (just dont do it in the dark, or break your grille when taking it off)
In the fuse box there is an empty space under a symbol which looks like full beam, this is where the fuse needs to go.
There are 3 wires going into the existing bulb, 1 earth, 1 for dipped lights, and 1 for full beam. Use a multimeter to figure out which wire is which. You also need to make a new earth or split the existing one.
Quote: Originally posted by hydeyho on 07 September 2005
Ill try to get a pic of how Ive done it for you
Cheers H , due next week so im gonna give it a go next weekend if i get a chance !!!!
