How would I "Show" the audio quality difference between 196k and a FLAC (800+) file?
  Not a 320d
As title. Im doing a project on compression, ive done the image now I need to do audio. Is there any way I can show this using a program screenshot?
Im guessing this is a retarded question but im looking for a way to depict the qualitative difference between the two showing the negative effects of compression.
  2.2 bar shed.
Re: How would I "Show" the audio quality difference between 196k and a FLAC (800+) fi
Sample sound wave, look at differences. Then you're just stuck with making sure your sampling gear isn't a limiting factor.
Tom
  EV (s)
File size. LOL.
  Not a 320d
Good point thanks.
Tom, thanks for the input. Ill be sure to come to you for future reccomendations when I need help. Im sure thatll get me a 2:1.
  Bus Winker
Use Audacity.
Put them side by side and you will be able to compare them and zoom right in.
  Not a 320d
Nice one thanks :)
sn00p
  A blue one.
FFT.
Take both versions of the file, pick (the same smallish section - a couple of seconds) in both and perform an FFT. This will give you a histogram which shows the frequency bands in both sections. The difference between the two files should be pretty obvious.
