As some of you may know I have been having some problems with my hub bearings. I had the bearings replaced about 1500 miles ago and recently the noise retuned and there was again some play in the wheel.
Having checked out a few things to do with the bearing going again I was told tat I should probably replace the hub as the bearing carrier was probably f**ked. I have just removed the old hub in the last couple of days and picked up another one from the scrappies. However having tried pacing the hub firmly down on a work bench and then rocking the disc there is a very very small amount of play to be felt in the original hub but with the one from the scrappies there is significantly more play. Also, when rotating the disc the hub previously on the c...ar rotates much more freely that th eone from the scrappies.
Basically what i was wondering is wether or not there should be any play at all (even very, very small) in the hub if you try and rock the disc? The reason I ask is that on the one just taken off the c...ar there is a very small amount of movement to be felt but you can't even see the movement visibly.
If this is not the cause of the play felt in the wheel then is there anything else that could be causing the problem that may need replaced?
If I just take the hub itself to a garage should they be able to tell me if the bearing needs replaced?
Thanks.
Thanks.
