Hub Fitting
mas
Car  MK7 GTD & Mini GP
hello all, right going to give changing my hubs to 16v so i can fit my coilovers today!!
can someone please break down in order what i exactly need to do, as in, which order do i remove things and loosen etc...
i dont have the foggiest, and the haynes manual could not get more difficult to read when it is covered in oil.
tips and tricks along the way people :cool:
thanks
Front Swivel Hub Removal.
I have assumed you have removed the brake calliper/front brake disk and axel nut.
First undo the nut on the track-rod end, use a ball-joint splitter, else you risk damaging the top of the nut. DON’T use the cheaper versions (pullers) get something similar to this >>
http://www.machinemart.co.uk/product.asp?p=040211222&r=2076&g=111
Second undo the nut and clamp on the suspension arm to hub and use the ball-joint splitter again, be careful not to damage the rubber gaiter.
I find doing the above awkward, so I usually undo the bolts on the lower arm (wishbone) and keep the lower arm ball-joint inplace.
Finally undo the strut to swivel hub bolts.
Now that everything is undone, all that is needed to do to remove the hub is a ‘gentle’ pull; it can be quite tough because thread locking fluid is applied to the splines, in that case get a rubber mallet and give it a bash. When done it will look like this>
….and the hub (with attached bottom ball joint)
Personally, I use new nut and bolts and thread lock everything where possible, you don’t need to though.
Good luck
Sam there's no way you will have the strength to do it on your own!!!! Theyve not be taken off in 12years;)
If the car is quite old and the nuts have seen better days, i would cake it in WD-40 the night before, makes things much easier.
thats a great guide mate!!!!!!
thanksyouuuuu
p.s - ad, just bcoz you bunch of poofs couldnt do it!
