I Need Aircon help??
If your pumps gone Ive got a spare one off my ph1 dunno if its the same as the ph2 and pipe work. They're well expensive from renault about £300-£500 iirc
could be somethings wrong with the pump & could be no gas in it or a leak
I had something go weird with mine a couple of week ago. The control unit wouldn't switch off and it wouldn't recognise the speed setting of the fan - it just stayed on top speed. It turned out to be the reostat, which I replaced for £35 from a breakers yard.
Could it not just be low on gas ?? i dunno what it would be like on low gashow often are you meny to get it regased??
Did you do the kit yourself? I tried that and after a few days it went back to the same as before and needed doing again.
