I need some help!
  2000 clio 1.4 sport
Hi, I've bought a written off clio and am in the process of getting it back on the road, at the moment i'm getting parts. Its a 1.4 sport, 2000 model. The airbox sits on top of the engine and theres an outlet towards the front of it where it looks like some sort of hose about 2 inches diameter should be attached. Anyone know what it is i'm missing? Any help would be much appreciated thanks
  2000 clio 1.4 sport
Please? Having done some more research i think its the cold air feed? So where can i get one from and is it just a hose? Lol as you've probably guessed i'm no mechanic :p
  Mk4 XR3i 90 - spec
If it's what im thinking then it'll be similar to my engine, and the pipe will be made of a cardboard type material, which goes from the airbox and other end resides behind the passenger side headlight.
It basicallt draws in air from a different position as apposed to hot air from atop the engine.
In my opinion you should leave it off, cause it makes a half decent induction noise. I used my pipe to feed cold air from the left of the radiator, don't know whether it actually works, but it passed the time lol.
  RB 182 & Lotus Evora
You need a cold air feed or the aixbox will just suck in hot air from the engine bay. Forget about getting a nice induction noise, you want performance, if you can call it that on a 1.4, either way you need all the ponies you can get, so get a cold air feed pipe and get it hooked up
  Mk4 XR3i 90 - spec
To be honest, there is no difference to be felt whether the pipe is on or off, so as for performance....
It's just a case of do you want a better noise, or not?
