I really really need to get to the bottom of this rattle. Please help!
  Looking for 182
Hello,
I've had this rattle for months now and I am losing patience.
Symptoms:
- Rattle which sounds like a bolt in a tin cat being spun around
- Comes from underneath the gear lever area, so is definitely around the front end somewhere
- Only occurs under acceleration
- Doesn't occur when stationary
- Is most prominent if the engine is under more strain, ie. going up a hill in 2nd/3rd
- Not so obvious when going at speeds above 60mph in 4th/5th
What I have tried:
- Secured and bent away more areas of heatshield than I care to count
- Bought a Milltek cat-back system (I wanted one anyway, the CAT is still original)
- Replaced the rusty manifold to cat fitting kit (the two spring bolts + gasket)
- Removed the plastic under tray from under the engine (a bolt was missing and when knocked this rattled, so I have taken it off but it didn't seem to be the cause of the rattle)
I am now thinking that it is an engine mount problem. Does any one have ANY thoughts or can shed any light on this issue?
DrR
  VW Golf GTD
Mines does the same, I noticed on mine the bolts that hold the manifold heat sheild on are loose, which makes the heatshield rattle if you tap it, but because of where the bolts are it's impossible to do them up.
Sheila’s’ Wheels’
  Whichever has fuel
You whacked the cat?
I had a scenic in last week and the cat had broken up inside and it was rattling like a load of grit inside a coke can.
Rob
Minor thread-jack...
I have a rattly noise, but don't have a CAT, I haven't checked ALL the heat shield yet though, I assumed it was my old backbox, but the new system does it too... suggestions danny?
It's only at a certain revs though, and is quite a unique little noise, but unpleasant.
  Megane 225 F1
Silly answer but on my 1.4 I had a rattle that I thought was coming from the exhaust. Turned out to be the air filter screws not done up tight enough so it was vibrating under accelertion.
  Looking for 182
i'd go with something in the cat. Didn't this car have a pretty big engine failure?
The CAT is certainly something which had crossed my mind.
At the moment I'm thinking it might be the manifold bashing on the sub-frame due to worn mounts. However (as danny mentioned) I did have a huge engine failure a couple of months ago and I had a new engine go in. I'm sure if the mounts were worn it would have been mentioned at the time. Therefore perhaps it is the CAT. I've whacked it but I can't hear anything out of the ordinary.
  Looking for 182
It's going to JMS on Monday next week for a service so they have kindly agreed to look into the rattle/knocking for me.
  Looking for 182
Unfortunately this still hasn't been fixed. James and Tom at JMS were kind enough to spend a few hours looking into it whilst it was serviced, and they tried a few things but to no avail. Unfortunately there was no access to a.....errrm, big car lifty up thing, so they weren't able to get access to things too easily.
I will be so unbelievably happy if/when this gets fixed. They've kindly offered to take another look at it but unfortunately I'm over an hour and a half away so it's a bit of a trek.
Got it booked in at a local 'specialist' this Monday for them to take another look with it up on the ramp (that's the word I was looking for). Fortunately I'll have a free courtesy car so I might just leave it with them if they can't fix it :p
Does anyone have ANY other ideas? Just something which might give the mechanic an idea.
  182FF
I have the exact same noise! Its only come on recently and like you say it really does your head in.
Let me know the garage find anything? Be great to know so i could sort this on mine.
  Looking for 182
Well, it's been in a local garage today and they called me to say they have fixed it. I am picking it up in an hour, so we shall see.
They say they have:
- Adjusted the heatshield
- Adjusted two of the engine mounts (can't remember which ones)
- Replaced a missing bracket on the airbox
It seems one of, or all of these have fixed the problem. I will be bloody happy if it has so that I can FINALLY enjoy the car after 6 months of ownership!!!
loose change in the cup holders behind the ashtray?
haha. If it had turned out to be that I would rip my own testicles off!
  Looking for 182
Well, I am amazed, but extremely happy to say that after around 3 months IT IS GONE!!! HURRAH!
I am so happy, it is FINALLY running as it should *touch wood*.
  172 Cup
Interesting, i have the exact same problem and its driving me mad, will check the mounts and air box, i've changed my back box, check all the heat shield to no avail
I have this problem and it's driving me crazy! By adjusting the Engine Mounts, what exactly does that mean? Just tightening up?
