ICE help!
  Clio's
After installing my sound system ive found that the front speakers and the subs are making a constant whining noise. this is not due to altenator whine as it is constant and occurs with only the ignition on aswell. ive tried a different amp, and it still happens. the speakers work unamped and the HU is still working fine. could this be a faulty wire? any help would be appreciated
thanks
  audi a6 3.0tdi
have you wired the rca lead next to the power cable? if you have try seperating these.
  Mustang, S13, AX GT
Mine did a similar thing but when the engine was running, I went to audio shop and got an inverter loop or something like that and it cured it. go down to an audio specialist shop they should be able to tell if you need the same thing. Sorry I cant be clearer I cant remember what the thing is called now, a something loop...
