I need to pick your brains again Please.
I posted about a month ago with referance to My valver cutting out after it gets hot, Wont idle. When i say dosnt idle it holds the revs sometimes but coming down from high revs to idle it cuts out. When the car restarts it is ok for a bit then will start again....
I have checked that the idle valve is working by blocking the inlet to it, at which the car trys to stall.
The thermostat is working correctly and the fan switch comes on at a bout half heat..
The coolant is at the correct level and mixture. Im ripping my hair out now as it was running fine for the last month. and now back to stage 1
Oh not sure if this is relevent but there is like a tapping noise coming from around the two injector at the end nearest the airfilter which is strange, but not tappets as were changed when engine rebuilt 12000 ago..?
