Renault clio II 1.6
clio has a problem with idle
Phase 2 clio 1.6 16v 2001
When i cold start its not a problem and the car goes up to about 1500rpm and then drops lower after a little while. The problem is when the car is hot. If i come to a red light and hold clutch and rpm starts dropping it ”catches itself at 900rpm and then gradually drops mire over next 15seconds and gets to 500rpm and runs quite lumpy. The car has no fault codes. The car ran like this when i bought it a month ago
What ive done so far.
Cleaned throttlebody
Changed map sensor
Cleaned tip of crankshaft position sensor
Did service with new air filter sparkplugs
New oe ignition coils
Checked for air leaks in intake with start gas but couldnt find anything.
Has anyone had same problem and if so how did you fix it?
Changed map sensor
