I have rectently done my heater matrix and now have some heat while i was dain it i snapped the key inside the igition barrol, which was very silly of me lol.
Does any have any guide or kin how easy or hard it is to remove one, n its for a mk1 clio
The barrel not to difficult to remove.
Remove the covers around the lock.
Then remove the little thorz bolt on the underside of the barrel.
Then unplug the wiring for the barrel
Then put the keys in and turn them to there second setting (I'm sure its the second if you cannot push the clips in keep messing about) and push the little clips in which hold the barel in if you try pull the berrel out witut pushing them in you'll see where they are a screwdriver will push them in.
Then just pull the barrel out and strip the barrel down.
