Ignition Barrel Change
Car  98 Clio 1.2 RN
Hi,
Can anyone tell me the best way to remove and refit an ignition barrel, my ones had it and it needs a complete new barrel and key.
If anyone could help me it would be much appreciated!
From what I remember when I removed the steering lock on mine, take the top bottom steering column plastics off, slide off the plastic (immobiliser) ring around barrel (un clip plug first maybe?) . There's a pozi drive screw at the top (or bottom), take out. There is a catch\detent which you have to fiddle with, (push with small screw driver) to get it to retract a bit and once this is over come the barrel will slide out, undo plug now or before. Reverse for fitting.
It is a lot easier than you think and as simple as I've explained.
Reviving an old thread here, what if the key won't turn in the lock? Is there still a way to do it?
