is it possible to modify other car ignition coil to CLIO RS?
my CLIO's getting lack of power, have change spark plug cable, and spark plug already. Can find any CLIO ignition coil in HK, so thinking to modify other's car ignition coil to it.
If its missing, turn your ignition off, take the engine cover off, then take all 4 10mms of the coils, and push the coils back in if you pulled them out, then start it up, and slowly lift each coil and listen to hear if its 'sparking'
