ignition key wire diag....
MaLicE
Honorary Member
  Lazy v8
i need to know some wires for the ignition key switch, i.e what they are so i can tap in to them, i need 12v constant, 12v ignition and accessory, if any 1 knows what the wires are, or has a haynes manual, please post them up its for a clio mrk 1 btw, but im guessing the wires would be same for other cars....
  172 cup,s2 rs turbo
one of the red wires is a 12v battery feed.the yellow is after ingnition and the orange is for the starter.just check them with a test light to find out what they are.
  Mrs' valver! &myV6 veccy
I believe theres 2 yellow wires.
1s the normal ignition live, the others the one where all the dash lights are on.
Summut like that anyway. Was in the max haynes manual!!!
  172 cup,s2 rs turbo
if there are 2 yellow wires then there the after ing feeds,red is battery feed and the other which i think is orange is the starter wire.all this can be checked with a test light though.
