have fitted my new twin headlights and have wired them up but have found a problem, the indicators work but when are used flash double time, as if missing a bulb, but theyre not. when u put the hazards on though they work fine, whys this guys
ha ha , they flash like normal on hazard. still all bulbs flash on indication but at double time, wots this resister lark about, someone else said that to me
The frequency of the relay which controls the rate of the indicators are determined by the combined resistence of the bulbs, hence when a bulb goes they flash faster (less resistence).
The hazards must work on a different (timed relay) for safety eg. youve broken down but one of your bulbs is gone.
so get a multi meter find the resistance around the circuit if for example its 10kohms and you want it to flash half as fast then put a 10kohm resisitor in the wiring? that mite sort it but im only a beginner eleci
yes it will help the flashing , by using the resistor, but it isnt right.
The lights should have been supplied correctly, i take it that they are not morette ones cos they come with a seperate indercator unit which fitts in to the bumper,. apparently i will find out cos mine will be here in 6 days.
there not the angel eyes ones are they?? cos they have intergrated indicators in them... which apparently are pain to get working...
