Induction Kit
  NEED V6!
My car needs to be checked for all sorts of faults at the mo, by having a induction kit does it affect the warranty.
Please help, cuz if so I'll need to put old filter back in before i take it to Dealer.:dapprove:
  NEED V6!
Cheers mate.
Quick Question? if the coolant gauge is moving up and down all the time and the steering feel light also yesterday pulled of in second and got no response from throttle for around 3 secs has the Aux belt gone, please advise as getting worried that if i take car out the engine going to die on me.
yellow182jon said:
Cheers mate.
Sounds like your coolent temperature sensor or its relevent wiring gone wrong its a common problem.
Your right in some way if the aux belt snams the power stearing and coolent pump dies but theat would mean the coolent gets hot and never goes down and your power stearing disappears and its very heavy to stear not very light.
As for why the stearings gone light have u hit any curbs sounds like your tracking maybe out.
  NEED V6!
Guess it's not the belt then, but the lack of power and the engine dying then coming back to life again that's just weird.
  NEED V6!
yes have hit curb's one at the rear and the front passenger side but did'nt think much of it till last week, is it expensive to put the tracking right.
  Monaco Blue Mk2
£30 tops for tracking.
My stearing was very light and twitchy when my tracking was out, I couldn't be arsed getting it sorted straight away as it wasn't bothering me too much, ended up needing a new front o/s tyre as it hand worn loads and uneavenly compared to others.
£30 to fit don't bother with Renault a good back street garage will got a better job hopefully nothing bent otherwise it can get expensive.
yellow182jon said:
What happens to the car if rain water were to get in the induction kit and carried onto through into the engine.
If enought got in it could cease the engine up but you'd need to get a fair bit in I'me never heard of it unless you drive thoguth deep pudedls with low mounted air intakes.
  NEED V6!
Had tyres and tracking done at just Tyres for £190 quid, car feels brillant know. Also called the AA Guy out to fix the coolant, there was alot of pressure that had built up and as he unscrewed the ca to the coolant it pop of around 2ft in air bit weird.
