Injection circuit open cylinder 3
  • Thread starter Thread starter Huffski
  • Start date Start date
H
Huffski
Rite I have had problems with misfiring so I changed all the ignition side of things because it needed to be done anyway but still the missfire happened. I got it plugged in and it came up with the error in the title above so I changed injector 3 with Injector 2 but the problem is still occurring anyone got any ideas the engine runs fine but it cuts in and out of the misfire so I'm guessing the compression is fine. Also just to clear something up cylinder 1 is the one closest to the flywheel ? Any help is very much appreciated
Did you get it plugged in again after you moved the injector?
to fault find the problem you ideally need a code reader, rstuner is ideal, with you while swapping bits over until the problem moves with the last part swapped.
Yeah it read on cylinder 3 before swapped them took it for a drive it started misfiring so I pulled over and plugged in the code reader an it came up with the same thing injection circuit open cylinder 3 hopefully getting it plugged in to a more advanced code reader at weekend
I'm bait stumped at the moment kind of thinking the ecu might be playing up
