inlet manifold question
^wrong
inlet manifold is the lower part, ie the bit that bolts to the head
they are all the same fitment (RS ones having larger ports)
the bit jonny is reffering to is the plenum chamber (the bit with "RENALT SPORT" written across it) they are model specific
is ther any point getting the lower part of the manifold if its from a 01 sport if i have a 04 182, it has been lightly ported and matched
Yeah my bad. You need upper (sorry Fred ;)) and lower inlets matching together ideally. Plus you'll most likely have an RS stamped one anyway, so less point.
