@ADVOCULTMOTORSPORT who has made that new PAS line kit might be able to help.
Maybe you've tried a dodgy column.
I've driven which felt lifeless and vague
Very happy with my currrent set up. Feels as good as I remember it with PAS. Plus I now have the option to adjust it when needed.
My 172 with a dCi rack and no assistance feels spot on. I'll be sticking the dCi column on and wiring up the EPAS module soon, I prefer no assistance for track but coming into a carpark without PAS is a bit of a fucker on the wrists![]()
Not thought about that. I'm not sure if you could use the BMW one and intercept speed input and then use that output to the EPAS box?Whats got me interested is programming the epas to increase/decrease resistance the slower/faster you go. That coupled with geometry changes to give more steering feedback/feel I reckon its not all bad!
My steering has got so much self centre demand I reckon its got more resistance than manual steering on an oem setup!!
You mean the e46 m3 csl pump? I watched that driftworks build and thats what he used he said it was progammable like the motorsport ones! I looked for those today funnily enough but didnt spend much time probably cost a lot more. I found this company that seem to be huge crooks and sell renault columns for 800 quid but market them as their own, they do adjustable assistance like from the ebay portugal guy and then a loom that connects of a speed reading thats what got me thinking.Not thought about that. I'm not sure if you could use the BMW one and intercept speed input and then use that output to the EPAS box?
This is what I was trying to make, was about to trim the plate around the block and then just fasten to under the rez bottle. Well It will come in handy for something Im sure
The DCi rack also has a steering angle sensor built into it, be interesting to see if an aftermarket ECU could control the assist on the motor for you.
I have a DTA S100 Pro, I'll ask Alex Chard (DTA Owner) at the Autosport Show on Friday if it can be done with a DTA?
Rich
You have the Pure PAS quickrack like me right?
I am still thinking of the electric pas pump.
How would you regulate pressure? With pump rpm or proper pressure regulator?
Very interested in your PAS fluid temps btw.
I had a word with Alex at AS20 and he said with the correct loom made between the DCi steering sensor and the EPAS motor control the DTA could easily control the assist on the motor you could build a completely custom map or just have a standard setup where you get more assist with more steering angle or even incorporate a speed input and adjust the assist by steering degrees vs mph of car, but said you could make it infinitely tunable.
Rich
EPAS is s**t, you can't feel what's going on at all.
Yeah you see, I know what that is now...![]()
Oooh done a course have we![]()
More the reason to get a proper ecu now! I wonder how much data could be used for the mapping of the assist, I had the idea of using yaw and cg data to make the steering assist more consistent since in a turn especially with the bank against you, the steering would be at its heaviest. Obviously you'd probably want some vary in assistance but you'd know if you were in bank regardless of how the wheel feels.
