ok so first i fitted a sub and an amp which works perfectly then on another occasion fitted some component speakers also wired to the amp. everything works perfect except there is an annoying crackling type sound when i turn it down or pause it. at first i thought it was a dodgy rca cable so i swapped it for the one that was in my sub and the sound went. so i bought a new cable to put in, did that ad then the sound came back so basically the sound is only there if both the sub and the speakers are connected.
any ideas?
Could be a few things mate;
1, Noise present with ign on but engine NOT running??? YES/NO
2, Does tone or pitch of noise alter in accordance to engine speed??? YES/NO
3, Do you have a Pioneer head unit??? YES/NO
4, Is noise present in all channels??? TWEETER/MID/SUB or ALL
5, Location of amp earth??? BOOT FLOOR/MOUNTING BOLT/REAR LIGHT CLUSTER EARTHING POINT
6, Are all items new???
7, Did you install everything yourself???
Simple test to locate fault;
System OFF
1, Remove RCA leads from amp---Switch system on & play as normal---Noise present = Amp or associated wiring issue, (most common is weak earth or speaker terminal shorting to door panel)......No noise present = Fault before amp stage......
System OFF
2, Plug RCA leads back into amp---Remove head unit from dash and remove RCA leads from head unit---Switch system on and play as normal---Noise present = RCA lead fault, replace leads......No noise indicates head unit or associated wiring fault......
Post up results for analysis......
