Instead of turbo price difference advantages + disadvantag
Sorry to be dumb but what is that? looks like the turbo parts the Cap I tan has on the other thread? or is that what throttle bodies look like on a 172?
  CTR EK9 turbo
theyre throttle bodies allright, but not sure what make I was just wondering whether it would be cheaper to go for them than a turbo?
Prima Racing I think do a conversion for £3000 to £4000 fitted. You can buy the parts for about £1500 but I havent found anyone yet who makes the inlet manifold required. Prima will obviously have this and might sell as a separate item. You would be looking at about 225 BHP @ the flywheel.
The biggest problems with all these power mods. is that it will be very difficult to find a standard insurer to cover the risk. It would mean using someone like Adrian Flux and gut feeling is it aint going to be cheap. But then if money aint an issue then thats cool.
For me personally id love either turbo, supercharger, throttle bodies and could splash out on it. What will put me off for time being is Insurance hike and being able to resell the car. So far I can change my car back to std. as Ive got the original parts and it would probably take 3 ot 4 hours to do so. Ill just have to be content with the decat, chip, steel hoses and dot 5.1 for now. Bloody house is taking all my money up :-(
  CTR EK9 turbo
Yeah, its always the money issue, GRRR!!! I need to win the lottery and then ill be sorted. Oh well, half the fun is saving up.....
Dash
  Clio v6
Ah such a loyal Clio owner. Wins the lottery and stays with Renault. We need more like you.
I personaly worry about how long the engine would last with these heavy sort of mods done, or am I just a sad old git maybe? Might all be worth one very fun filled weekend though.
Simon I think of all those things the Turbo would be the most expensive considering the need for lower compression pistons. I would say the supercharger would be very nice Throttle bodies are 4000k fitted from Hillpower I think. He didnt say exact horsepower figures but did say over 200Bhp. Another thing is the throttle bodies would be a lot easier on the gearbox + clutch.
Chun.
  CTR EK9 turbo
I see what ya saying. The supercharger would be nice. Are the non-manifold bodies any cheaper? Ive heard its better to get without, not the weber alpha jobbies. Throttles would sound awesome too!
you wont fid much difference between direct to head bodies and thise which use existing dcoe manifolds.
unless your building a full race engine, normal TBs will be no different to direct ot head jobbies. its all in the setting up and elctronics/mapping.
But injector placing and sequencing is also super important....and weather you use a twin injector system or not etc etc.
  CTR EK9 turbo
BenR, if you had around £3000 to spend on your engine, would it be a turbo kit or throttle bodies?? or a supercharger?
im not too fond of turbos as the power delivery on big boost items can get sketchy mid corner......so its not so much fun to drive at the limit.
charger is good, but the amountof work doenst warrent it i think.
its gotta be TBs for me. Easy to tune, easy to make/fix/modify. the head is the limiting factor. a good 240bhp should be attainable if you work hard enough at the head. the S1600 are restricted to a single 40mm inlet (just bigger than 1 inlet valve on the 172!!!) and make 220bhp on a single TB.....its all down to how good you are.
3000quid wouldnt get you a drive in drive out turbo or charger conversion though, you would need to do alot of the plumbing in.
  CTR EK9 turbo
Yup, I agree with you totally. Ive always admired throttle bodies and also the sound is amazing! just think what it would sound like on a 172!! "rrrrrroooooooaaaaaaap!!!" (sorry, got carried away there! )
this is interesting ...
ok... Supercharging and turbocharing is effectively one and the same !.. the source of power is different only.
you still need lower comp - preferably forged pistons...
Now for bodies...
You need, as do the above.. an independent engine management computer at at least 500 quid plus vat..
then another 500 to get it mapped...
On costs...
the turbocharging is the most expensive at about 3500 in parts and mapping. (and that is presuming a grand for the mechanical parts of the exhaust / induction syste) Reno prices would be about 2500 more.. so.. to do it properly with genuine parts - about 6k
Supercharging... no exhaust mods... charger is about 1500.. brackets and mounting about 200... pipework and intercooler about 225 - so.. about 1925 - call it 2k.. plus a grand for the ecu and mapping.. so.. 3k - then, ya still need the low comp forged uppy downy thingies... say.. a grand again.. so.. cost 4k
Throttle bodies.. Jenvey make them in the uk.. cost about a 1400 for the full kit... with sensors and fuel rail mods..
Laser cut adapters to fit the bodies to your head - your own VERY simple design... including aluminium - about 75 !!!!!
ECU and mapping..a grand.. so 2400
these prices are for parts only - but labour is included for mapping time on the rollers at a total cost of 500.. could be as high as 800...
Driveability...
Turbo.. too many people are not aware that a turbo can be tamed.. old tech cars like the 5gtt, porcheT - any damn turbo was given the reputation of being a handful due to agressive power delivery.. that is stoneage now though.. a mapped boost control monitoring rpm and throttle position can make the turbo the car of your dreams... it shouldnt be abrupt.. shouldnt spool the power up suddenly whilst accelerating hard... all it should feel like is having a far bigger, more torque delivering lump at the sharp end...
but.. there may be times.. 25 degrees (C) lol... clear roads... ya know... you want to get a kick in the back from a bootfull on the limit of traction (cos thats when you have exceded the design limits of the chassis ... easy.. press a button and select map 2 for the boost... look at mammy Im dancin type stuff lol..
the supercharger.. bloody excellent all round... what the turbo has to be programmed to feel like.. no option for brute force silliness and fun ......
tbs... the noise would drive you insane unless the car was a toy for occasional blasts... I know.. !
When it works though.. it works baaaddddddd .. the sound is heaven.. but.. like a babies first cry that seems like an angel crying.... .. it soon becomes a pain in the ass when you are tired !
Joe.. so there !
I Forgot to add the other tangible benefits of tbs ..
ok... you WILL get INSTANT response from yer lump... it is very noticable when compared to an injected - especially fly by wire) system..
the increase in breathability of the simple airpump (read engine) is enhanced.. showing conclusively that exhaust changes unless serious tuning has taken place are worth Jack !.
oooops, sorry, that slipped out lol..
and because of the above.. how bout an extra 40 BHP.. hmmmmmm.. about 200 bhp at the fly... say.. 150 GENUINE at the wheels.. maybe 165 on a good day...
The supercharger and turbocharger can be be tuned to deliver high boost hence power.. the turbo will ALWAYS be more tunable, adatable and scalable than the supercharger though.
as for power.. name yer poison ! ???
what do you want ??..
assuming the need to keep most items standard (apart from the low comp forgies).. the say...
260 bhp at the fly. say a realistic 200 bhp AT THE WHEELS..
now.. you more importantly got a torque curve to die for that the tbs will never, ever get a glimpse of...
if that torque is controllable with boost regulation - you have the ultimate.. I intend to have3 seperate boost maps in mine...
1. Normal.. everyday driving with a smooth power delivery..
2. rapid production of power with kick in the pants take off... just wound back a notch from limits of traction on chassis.. ie - every time it scares you TWICE, you wind it back a tad LOL...
3. TNB switch.
Joe
Forget it they want 150,000 Yen for it which equates to just under £800.
Captain you know where to get a larger throttle body from on the cheap? will it make any difference?
you can modify the standard TB as its not very good interms of outright flow. But, you would need to do flow tests to be accurate.
Captain:
well done mate.
i used ot go into pages and pages of detail, you might be able to find some (i rant on about overlap and back pressure, how standard exhausts are the only ones that are actually tunned by the manufacturers, and other theory mumble jumble) but i stopped now, never got any interested response, the thread tended to fade away.......now i have somebody to talk to!!!!! yay!!
As far as forced indution goes, comming form a racing background, its not my favourate (since race items tend to forget tractability and go for outright power, which can be scary! especially having to decide weather a long curve need a shift in the middle of a short shift before) but super charges are AOK with me.....its just the plumbing in in small bay that puts me off, especially when you have to weaken the shell by cuttin and shutting, thts why my MK1 XR2 remains a 4 speed and not got a MK2 5 speed in, i dun wanna cut across the support rail!!!
And im really into N/A tunning, pulse tunning theory (especially the use of trumpets/tunned lengths and pulse plates) heads are fun to work on, and exhaust systems are good fun too, easpecially working on primary and secondary lengths. I dont have too good a head for numbers, but i can visualise flow patters (if that means anything to you) in my head and i usually get them right, same goes for most theory, i viasualise it with diagrams in my head....cant put things down on paper...never works.
CHeers
Ben
Hio Guys..
Simon, the throttle body size on the single unit is often connsidered a weak point or restriction.
Early golf gti tuners (VW Rabbit in US) had a craze for increasing the tb size..
when actually tested it didnt do anything apart from move the torque curve up slightly, hence reducing low end pulling power.
There is a maze of theory regarding pusle tuning, inlet tract length etc..
a lot depends on the design of the plenum chamber (the box with inlet pipes going to your cylinder head)
the bottom line is that bigger is not always better, and as Ben rightly says, it needs to be dynoed to see the results.
imagine HOW the intake charge air is induced into the cylinder, the cylinder goes down due to the expansion of the ignited mixture, as the piston passes C (bottom dead centre) the exhaust valve opens and the whole lot exits at high speed into the exhaust manifold.
now the inlet valve opens as the piston starts its downward cycle 1 rev later.
We now have a dual effect, vaccum created by the downward travellinmg piston and also a little factor called overlap of the valve timing meaning that at a certain point the exhaust valve and inlet are still effectively open.. the high pressure exhaust pulse exiting the engine causes an even greater vacuum or pressure differential in the cylinder as compare to manifold air... the inlet charge is drawn in. yep ?
now, if the inlet system consists of an air holder device.. ie - inlet tract tube / plenum or throttle body unit that is sized correctly for the volume of air, then not only do we have a charge ready to inhale, but the SIZE of the orafice that leads to outside air becomes critical for power delivery.. why ??.
Well, wouldnt it be nice to NOT have a huge opening to atmospheric air.. have a slight restrictor, the reason for this is to allow still another pressure differential to happen between the intake valve when sh*t and the intake from the air outside... this causes a high gas velocity / flow rate and the charge holder or inlet tract / pipe is filled ready for the next intake.
air is a fluid to all intents, can you picture the turbulence at the intakes if no pre charge length was used ??.. ) it would be chaos with each induction interfering with the next.. as air is induced rapidly, and stops being induced rapidly, a layer of distured air exists at the intake that will reduce power by making the gas flow uneven. Providing the length and volume of the pipes is designed correctly, then you can have enough charge in the intake pipe ready for the next cycle, and keep the disturbed boundry layer out of the system. The pipe will be effectively recharched ready for the next induction.
AND this is only effective a t one point in the rpm / load range. so all other areas have to be a compromise.
bottom line.. it aint that simple lol...
we could start discussing why a free flow exhaust is more often than not BAD for power in another thread.
Joe
agree, but were you explaining that to me? kinda knew that.
gas velocity is an all importent part of tunning.....agreed!!!!
Man, i should marry you!!!!
but im talking that if you make the TB larger....than you would have to modify the enf\gine to make use of the reduced restriction....so basically, i was just meaning very high rpm power geains, especially if you could get it to rev ot 9000rpm or so.
Hi Ben LOL
not adressed at you Sir no .. just generally and in reply to simons question..
yes, if you changed ot for increased flow at high rpm (IF, and only if..it was actually causing a restriction in the first place) then yes...
but the bottom end would suffer.
cheers m8
Joe
