instrument/park lights not going
Car  Renault clio 16V Dimma
Can anyone help? Instrument /park lights along with all interior lights ie window switches etc flicked on and off afew times then completely went off. Courtesy light still works. Main Headlamps and indicators still go. Just park and instrument lights gone.
Have checked all the fuses, none of them have blown as far as I can see.
May be a faulty relay switch? Does anyone know the exact location for the relay which controls the park lights? Also the fuse which controls the parklights? I have ordered a workshop manual but it has not arrived yet so not able to look it up.
Check the bulbs! All the relays are under the glove box. Im not too sure but id say bulbs, though i cant see how all would go out at the same time. Also the relays dont control the whole panel they control things that are timed, like, window wipers and indicators.
Found the problem. It was the light swicth stalk. Had faulty contacts. Managed to pull apart, clean all contacts and re-assemble. Not an easy task. I don't think they are supposed to be pulled apart.
Anyway all fine now.
