Interior Fan
  Clio MK2 (1.2)
Came home from work and switched the Fan to clear the windscreen and nothing happend, :dapprove: left it on to see if it would eventuly come and it did, so me beeing clever decided to switch it off and back on that only made it not to work again :mad:
i was thinkin maybe a fuse has gone ?
Help guys its raining and i need the fan to work :(
  Clio MK2 (1.2)
will have to give it a look later when it stops raining, thishappend to my ast car aswell .. :(
Its the resister pack £90 from Renault for a new one.
Its easy to change its under the scuttle panel under the bonnet.
  clio 172
if you remove the plug from the blower under the scuttle panel you can put a link across the 2 outside pins of the plug and this runs the heaters flat out, this will then prove the resistor pack is the problem
  clio 172
This is the part you are looking for, under the drivers side of the windscreen
Bought mine from a scrappy for £30
  Clio MK2 (1.2)
Great £100 just before christmas :( lucky i got the back pay,
now how do i find my nearest Renault ?
Cookie
Find your local scrappy first, if that fails go on the Renault.co.uk site, I'm sure there's a dealer locator on there
  Clio MK2 (1.2)
ta cookie,
it worked straight away this mornin on the way to work tho, couldit be a wire lose or is it deffo the Resistor pack ?
Could you not whip it out and just check the connections maybe clean up any corrosion etc..?? or is that a waste of time.
Yep you cna do nd repiar them this way usualy but msot people would ruin them when trying to fix them so no point explaianing it.
ahh okay cool, might be worth trying anyway then just be careful and expect to probably spunk 80 quid or whatever for a new 1
  Monaco Ph2 172
Bizarre - my heater started playing up with the exact same symptoms earlier this week. It's very intermittent, but the fans are dead when the car is started but usually come on after 10-15 minutes.
Sounds like a fairly straightforward task to undertake myself, so thanks for the info guys. :)
  Clio 182 FF
Got the same problem, thanks guys for the above help and the picture where the scuttle panel is. superb help.
  Clio 182 FF
Nightmare, just fitted my new resister pack, cost £102 inc vat, blooming fans are still playing up.
I will have to book it in at renault just so that they can charge me £60 to tell me theres nothing wrong.
  mk1 172
Got this problem too
Changed the resistor pack with one from cliospares, and still nothing. What do I try next???
This time of year is not the time to not be able to demist the windows!
Its on a Mk1 172 btw
Anyone have any ideas???
  172 Race Car
either the fan or the switch. I have a complete fan for sale for a phase 1. came off a W plate car.
looking at this thread it looks different to the climite cars one. Or I clould of been some help to others
  mk1 172
How much do you want for the fan??
I disassembled the lot and connected my fan directly to the battery and it did nothing, so I'm guessing its the fan thats knackered as I brought a new resistor pack and thats not made a difference
