Intermittent Deadd Battery / Short?
  CLS320 with a D6
Every week or two, I will go to start the car and all the lights come on then off (pre-flight) then go to crank and there's a crank or two of the motor then 'click' and everything is dead. Try again and its the same but less cranks, or half of one. If i get bumped then drive for a minute, then turn off the engine and try again, its fine.
Had the battery tested and its missing about 40 CCA's but advised is not really an issue.
Any ideas?
Car is Phase 1 172
DaveDreads
Get a new battery from Halfords, if it doesn't solve it you can get a refund,
I had very similar issues on my 172 and a new battery solved them.
  CLS320 with a D6
Cheers for the tip Dreads, presume its one of the no fuss 14 day return things.
Got a trade card the other day so will bust its hymen
  CLS320 with a D6
For info I have had a new battery for a couple weeks now and all is well so far
  Westfield, 182, 200
Had a company car with a knackered battery, i had to jump start it every morning. Vauxhall tested it and said it was fine. persuaded my company to buy a new battery and it cured it.
Problem was, every time Vauxhall tested it, i'd been driving for an hour, so the battery was charged up!
Lesson learned!
