Hi all,
Ive got a 172 ph2 02 plate recently it struggles to select gears intermittent fault, Before posting ive changed obvious bits etc, dogbone has black series mounts fitted, vibra technic top gearbox mount, vibra technic engine mount, overal im very impressed with these, transformed the car!..
Selecting gears has improved, but sometimes reverse will select lovely then other time grind like hell, if im giving it a boot full at high revs it doesnt select untill the revs drop down and this still isnt the smoothest gearchange, other times i can be coming into a roundabout trying to drop a gear and it will lock me out and wont let me select any, and if it does its harsh and clunky. So i got a mix of very smooth changes to clunky changes. not often but if its having a episode of playing up i could be stationary in first with clutch down and the cars vibrating and dropping revs as if im letting off the clutch.
Ive ordered a clutch cable genuine from renault as i here the mickey mouse ones are dogsh*t. im also running a carbon kevlar paddle clutch cause this have stretched my cable? or could my cable be sticking?.. I cant see how it can be so intermittent? Does is sound like the gear linkages need adjusting?
Any help is much appreciated! Id like to think i wont be having to change the clutch or box
