I am experiencing some intermittent starting problems with my 182. It seems to crank over but not fire and I’ve noticed it’s more likely to start from cold then it will when it’s warm. When I’m idling the engine management light flashes but stops once I start driving. I have had my local garage and the RAC run some diagnostic checks but neither of them have picked up any logged faults. The Renault garage in Swindon has quoted me £96 for a diagnostic check but I’m not prepared to pay that type of money for them to tell me they can’t find any faults. Is there a chance that Renault may pick up fault which were not picked up by my local garage or RAC? I’m a little lost as to where the problem might be but I suspect a problem with the ignition or fuel system. I’ll check the coil pack, leads, plugs and injectors over the weekend but if anyone has experienced similar problems I would appreciate if you could point me in the right direction.
