intermittent warning lights
Car  corsa D / 172 clio
hi :D
every now and again my warning lights come up on the dash of my 2004 182.
its the esp,abs and service lights.
its been doing it for a few months now and there doesn't seem to be any pattern or
circumstances to indicate when they might light up its just happens whenever!!:(
the only thing that gives it away is that the brakes become really good before the lights
come on if that makes any sense?
don't get me wrong the brakes work fine its just that they really stop well just before the
lights come up.
if i flick the ignition on and off the lights go out and might not come on again for a
couple of days or even a week!:S
i have replaced all the discs and pads,checked all the abs rings (cleaned them with a
toothbrush and brake cleaner) but still the lights come up:mad: bloody lights are driving me
mad!!!!
someone i know with a 182 had the same problem and fixed his by replacing the brake
light switch on the pedal i can do this easy enough but it doesn't explain why the brakes
get better before the lights flash up.
any help would be much appreciated
thanks:D
With anything like this i would start by just going around the engine bay and battery cleaning all earths of rust and dirt and then coating them in vaseline (petroleum jelly) as it sounds like a bad earth issues to me and also just check all fuses and relays are working as a matter of course......
thanks mate i will check that lot out!
ive got a new brake light switch today so i will fit that tommorow aswell so hopefully it will sort it out.
