Ipad asking for 6 digit passcode instead of 4
I've had the work's ipad sitting doing nothing over lockdown. It had a 4 digit passcode set up on it to unlock it. But I've just turned it on and it's asking for a 6 digit code. WTF? :LOL:
No I haven't been in to work yet. It doesn't make sense because I've switched it off and on a few times since being stuck at home and it only asked for the 4 digit code until now. Do apple normally have 2 different codes?
Dom_capper
  2012 Renault Clio
I’ve had times when I’ve been logging into iCloud and it’s asked me for the passwords of my Mac and iPad to sign in on my phone. Does it definitely want your iPad password and not an associated iPhone password?
It just says ipad requires your passcode after restarting. I think my boss set it up on his apple account so maybe it wants his account code? Doesn't make sense to me
Typhoon
Gangsta
I’m sure one of the “locked” features (stolen mode etc) options is to require a 6 digit for some reason or another.
Daz...
  Inferno 182 Cup
All newer iPads have 6 digit codes, it’s only the ones on older versions of iOS that need 4.
Dom_capper
  2012 Renault Clio
Doubt that’s on the cards! Someone at work/Apple will be able to get in surely?
Dom_capper
  2012 Renault Clio
Apple support is very good. But if it’s owned by work you will probably have to go through them
  Clio 197
Tried entering 000000/123456?
Found from elsewhere: "It should say passcode options just below the 6 spaces for your code. Tap the options and change it to 4".
Typhoon
Gangsta
Im sure the “passcode options” link where you can change between 4/6/alphanumerical is in the settings when you go to set a passcode, not when you’re locked out.
@Pistachio - sorry, not overly sure what else would trigger it. I’m only aware of remote locking causing it to have 6 on occasion
Ben
You’ll not be able to wipe it without the code. Just ask your boss what the code is? If it was 4 and now 6 someone has changed it.
  Clio 197
That's what I thought too but the post suggested otherwise.
You can still restore it without the passcode by putting it in recovery mode and connecting to iTunes iirc.
