is this true
Ol’ Tarby
  Clio 220 Trophy
my m8 says that if he takes the battery off on his mk3 clio then the ecu will lose all its programin and the car wont start and it will need goin back to renault, i think it sounds a bit stupid but is he right?
Ol’ Tarby
  Clio 220 Trophy
thats exactly wot i said to him! he had sum problems wiv his car cuttin, so he took it to renault and he says they put a program on the ecu that would automatically rev the engine slightly wen it was gonna cut. i think renault hav been fillin his head wiv crap
  ex Clio 172 owner :(
I have this problem with my Saxo VTS. Its a common fault with them, they want to stall when idling. I was told by someone, disconnect the battery for about an hour and itll sort itself, I told this to someone else and they said itd screw your ecu if it had no power for that long. The stalling is still happening and I dont know whether to try it. I must have the car working, so until now Ive left well alone.
I had a similar problem with my escort which was one of the reason that I got rid of it.
Taking the battery of the cars wont do any problems it may reset the Ecu and any learning that the Ecu has done will be forgotten. But it wont forget how to run.
I would try the removing of the battery. But I cannot see that fixing the problem its most likly some doggy sensor giving the wrong readings to the ECU.
If you remove the battery dont forget to make a note of the radio setting and radio code as it will forget then and need them reinputting when you try and tur it on again.
Removing the battery wont do your car any harm the ECU is a safe Ie it cannot be deleted when you take the power away.
EDD
  Skoda Fabia vRS
there are VERY VERY few cars that lose the ECU memory if the batt is disconnected, and the likes of Cit/Renault dont fall into that small amount of cars...........
IIRC its one or 2 Jap cars.........
so your mate is wrong....
