IT’s Alive!!!
I finaly startet my 2.0 today. It of course sounded terrible at first with the cam punding away. But when it got warm it sounded very nice. I will take it out tomorow, cant wait.
I will never change engines again w/o checking the triggerpionts again. Thanks to everyone who has helped me with info along the way. Espesialy BenR and Cliokongen!! W/O you I would still be wondering why I had a 2 cylinder clio :oops:
Again, more pics on http://www.ruf911.com/clio3.htmlhttp://www.ruf911.com/clio3.html
The 172 missing its partner...
http://www.ruf911.com/clio/mont_9.jpg
Megane and Clio flywheel. Triggerpoints marked with tape.
http://www.ruf911.com/clio/mont_8.jpghttp://www.ruf911.com/clio/mont_8.jpg
http://www.ruf911.com/clio/mont_10.jpg
WHOOOO HOOOO!!!!
great, one day i will come meet you at the ring.
anyway, what was wrong with your cam?
the lifters not pumping up properly?
There is nothing wrong whit the cam. Just the lifters which have been out of a business for a loong time. I used a spare head for the 2.0. So I still have a spare 1.8. Will se what is wrong with the crank soon. It is locked:eek:
Quote: Originally posted by BenR on 03 June 2003
oh, dont forget to get a checkup from ren, see the potentiometer reset.
Come again? To get the throtle and idle right u mean? Should I wait for my willy ECU to arrive to do that?
oh dear........oil starvation?
It is in my belive that hydraulic lifters which have been standing still for a while does sound a little at first. No such sound now.
no, i mean the crank, has the crank suffered from starvation?
and yes to the potentiometer.
On the old engine: I started to feel the engine had less power, at the end of the ring I started to get a hammering sound. I drove slowly to the pit. There I manage to stall it. And the engine is locked ever since. Lycky me I ahde the Clio on a trailer for easter... Havent open up the block yet, the pistons are loose, but the crank is stuck.
  ITB Hybrid+Cup+Scenic II
Wooooooo Hooooooo....
Finally!!!! :D Always very exciting to start an engine after a reassembly... The crank should not have suffered from oil starvation if you made oilpressure with the starter (no leads attached/plugs)... ?!
I always keep my lifters in a bath with oil, so they don´t leak... But should´t really matter.... But the lifter noise will stop earlier!
Great pics... If you 2 madmen and others are going to the Ring.. Then i´m there!!!!! :cool: Just need too finish my lillte engine project first!!!
Michael
BenR: Can Renault check the position of the potentiometer and reset the idle.....? The dealers here in DK are totally crap.... Don´t think they would know how.... Do they use the XR25? (I think it´s called!)
Michael
The crank problem was on my old engine, cliokongen. The new engine had been getting a lot of oil before starting considering when I was checking why it dident start with the megane flywheel...
Tell us more about the potentiometer adjusting Ben!!!:D
Would bee cool to se som clios at the Ring. I am hoping to go in 14 days if the 16v is running fine/and my willy ECU will arive in time. My last trip of the year (september) will be by plane and rental, so next year it is... :(
The XR25 gets plugged in and the TPS is adjusted until a pre determind voltage is gained at which point the TPS is correctly positioned.
You can do it with a voltmeter but I forgot what the voltage is meant to be.
