it is worth to change this mount?
Car  Clio sport phII
Hi!
I already changed all engine mounts in my 172 ph2, and still hear knocking exhaust sound (only on 1st gear above 5000rpm when loose tracktion, and esp i on) I have dog bone mount poliurethane. I noticed also, that the gear stick is moving a little when i relase the gas pedal.
My question is: It is worth to change also this mount? :
Cheers!
On the small end it should be offset with the longer bit upwards, if not it can tip the engine back a tad and the exhaust can knock on the anti roll bar.
