ITG Maxogen
Car  RenaultSport clio 182 mk2
Where's the best/cheapest place to get 1 of these?? I've got a viper and i now have seen the light and going to fork out for the maxogen.
Cheers, Jaff
Go for the non carbon. Slightly cheaper but exactly the same ;)
Probably ITG themselfs unless you get lucky on the bay
I saw the light and realised induction kits are a BIG rip off and a complete waste of time!
Seriously don`t waste your money on any aftermarket induction kit if you want performance gains!
I went through this phase and after running mine on a dyno i found losses in inlet manifold pressure when using aftermarket systems like BMC and ITG Maxogen, compared to the clio box!
If you want gains on the inlet you need to go for ITB's.
Knows. And pocket the £150 saved! ;)
IK's make bugger all difference on Clios anyway. A drop-in ITG panel in the standard box does the job very efficiently!
Espace V6 box with ITG panel seems to be the way forward.
Had a Simota myself and it felt noticeably worse!
ITG maxogen money to make your car sound better = more money than sense. I know people on here big them up massively but seriously an ITG panel fliter and CAF will do the job for £200 less which you could then spend on getting your inlet matched and a de-cat. In total seeing you an increase in 5-6bhp rather than a loss.
Well i've had the inlets matched and had the de-cat. Was gonna see if the maxogen made much difference over the viper.
I would be surprised if you will hear the diffrence from the ITG max when running a de-cat, esecially if you have a full system
the viper/venom is very good if set up with an identical diameter 90deg bend after the throttle body, heat wrapped with a short cold air feed
Good thing about the Maxogen is you'll get most if not all of your money back when it comes to sellin up n changin cars, thats how i justified it anyways :D
As for where to buy one i got mine of CS :D
GDi's was running over 200 bhp with a Viper a few years ago
GDi also ran 240 bhp with a IK of the open sort (forget the CAF biz and coldest part of the engine aside)
Many cars on here are well over the 200 bhp with mods and IK's fitted
Chris and Nic got a 14.2 with a CDA and very little over mods.
Armed with this, cant see they doo too much harm in the way of performance ....
overpriced and overrated
I know you rate the Viper Fred. Now this is a piece of kit thats only 100 quid cheaper than a Maxogen.
Im guessing youve seen a Maxogen? Leaving the peformance difference aside the quality of the Maxogen kit, design and look of the kit is easily worth 100 quid more alone! and thats before you come to flog it for a loss of only 50% compared to 2/3'd with a Viper and thats if your lucky.
Really isnt that bad a value if you look at the bigger picture and compare.
its a clio, not an LMP1 racer, sorry chaps but i do not see the point in speding £350 on an induction kit where you could have an awesome setup for under £100
as i've said for years a 200bhp clio with an average driver will be ebarrased by a standard clio with a well trained experienced driver, i know where i would spend my money first!
don't get me wrong, by all means spend your cash, its your hard earned afterall, and we all love cars and are all enthusiasts, i guess my point here is don't assume "item X" is the best because people on here say so and because its the most expensive! look what happened when people thought sod spending £350 on a maxogen, i can knock one up for under £100 from an old espace V6 airbox and a bit of pipe, its not as pretty, but its just as good
Iv had a ph1 air box, Viper and a Maxogen.
Airbox was s**t IMO , Viper was the best VFM till the foam tore and i had to stick it in the bin. £230 down the drain. Wont have that prob with the Maxogen.
Spend your money on your needs and what your wanting from your car.
Not much point buying a 350 IK if thats going to be your only mod or if your going to flog your car after 3 months.
Like wise not much point in modding the **** out of your motor, spending £££££££ and only having a 10 pence IK up front..
i still don't see what's wrong with a standard pannel filter, grass track and rallyX boys use them and they have a little bit more than 200bhp, the GT3 RSR racers use a boggo pannel filter
O how convenient.
Im trying to arrange another rolling road on that chassis one i went to, but do 3 seperate runs, maxogen, standard box and an open filter moved to behind the light.
Im interested to see what the results would be.
so should i stick with the viper or put my airbox back in and put a itg panel filter in???
Yeah i'll see how much different it is to the viper. I did find the viper gave me better response over the standard box with a itg panel in it. So i'll see how this preforms :D
Jaff
