JavaScript help
  clio 182 black /gold
(i) A JavaScript program is intended to accept two numbers from a user,
then write the sum and difference of the two numbers to the browser
window. For example, if the user inputs 36 and 24 the program should
write
The sum of 36 and 24 is 60
The difference of 36 and 24 is 12
However, the current version (Figure 6) contains several errors. Your
task is to identify them, correct the program, and write a short
explanation of each of your changes.
<SCRIPT LANGUAGE="JavaScript">
// A program to find the sum and difference of two numbers
var firstNum;
varsecondNum;
firstNum = window.prompt('Please enter the first number., '');
firstNum = ParseFloat(firstNum);
secondNum = window.prompt('Please enter the second number', '');
secondNum = parseFloat(secondNum);
document.write'The sum of ' + first + ' and ' + secondNum + ' is
' + (firstNum + secondNum) + '<BR>');
document.write('The difference of ' firstNum + ' and ' +
secondNum + ' is ' + (firstNum+ secondNum) + <BR>);
</SCRIPT>
Yes. Im bad:( but just need another pair of eyes to go over it. It is for my uni course.
  Megane DCi 147bhp/350nwm
I've found a few but unfortunatly i'm not very good at javascript...
A few miss placed commas, full stops & spaces
KDF
  Audi TT Stronic
Code:
<SCRIPT type="text/JavaScript">
var firstNum = window.prompt("Please enter the first number");
var secondNum = window.prompt("Please enter the second number");
var answer = parseInt(firstNum) + parseInt(secondNum);
document.write('The sum of ' + firstNum + ' and ' + secondNum + ' is ' + answer  + '<BR>');
document.write('The difference of ' + firstNum + ' and ' + secondNum + ' is ' + (firstNum - secondNum) + '<BR>');
</SCRIPT>
I sorta improved the script aswel heh..
  Rav4
Much, much better !
Code:
</SCRIPT>
