JB1 lsd
Car  renault twingo cup
I am building a racing twingo for circuit and would like to install LSD to a JB1 gearbox. Any Ideas where to get it?
we must run 1.2 l engine
Well assuming the jb1 gearbox runs the same size diff as a jb3/jc5, you’ve got a few options. I can supply and fit a Quaife or a gripper. Unfortunately I don’t know if they share the same sized diff.
Whereabouts in the world are you mate?
What's the difference between those two? Sorry but lsd is new to me. 💔💔💔
So the Quaife is what’s known as a automatic torque biasing differential, so it sends drive to the wheel that’s spinning, but it never fully locks giving 100% drive. A gripper is a plate diff. This means the amount of lock up the diff gives can be setup according to the desired usage. However, the gripper will need servicing to maintain the preload.
The Quaife is fit and forget.
You can build both of them over in Slovenia, but you’ll need to get someone to fit the original crownwheel to both diffs.
how much is such lsd
