JBL AMP HELP
I cant remember if that amp is 2ohm stable per channel but if it is then technically yes. If it is only 4ohm per channel then no but you could risk it for speakers.
If both sets of components are going in the front then you could use 2 channels to run both sets, the othr 2 channels for the 6x9s and bridge the third 2 for the sub.
If 1 set of components is going in the rear then you will either have to lose the fade function or run a set of componets and 6x9s off the same channel but then you might have problems setting the gains.
The sub channel is 4ohm stable so you will need a single voice coil 4 ohm sub or a dual 2ohm sub wired in series rated at 200-250 watts RMS
The components and 6x9s should be rated between 50 and 75watts RMS
Most people dont run 6x9s alongside subs though as it degrades the sound quality. You may or may not have heard that before.
Hope that helps.
Russ
