Jc5 130 gearbox advice
Tomo3292
Car  Clio 1.6 K4m
Gents need some advice.
I bought a clio 172 with no gearbox as part of an on going rally car project.
Basically me and my brother are gonna have a go at the sport on a budget.
Cars undergone a full rebuild, including Perspex windows, mark fish x door bar roll cage, 172 engine refresh, and now hunting down a gearbox for it.
Basically not to sure what gearbox I need and a bit unsure what connectors are on my loom.
Are all jc5 130 boxes the same???
Guessing mine is speedo driven hence the jc5 130 question.
Many thanks
JC5 089 - Ph1 172 Longer final drive and speedo drive
JC5 129 - Ph2 172 Speedo drive
JC5 130 - 182 and some late Ph2 172's Mechanically the same as 129 but no speedo drive
Oh right then so I actually need a 172 JC5 129 then??
Wasn't aware of that.
Thought I actually needed a jc5 130
If you can get a speedo drive box but add a diff from a 130, as these have the bolt in diff, not circlips which are known to pop if you have a heavy right foot. So if used for rallying, especially on a loose surface, the 129 circlip may not last long.
Many thanks for that mate. I have done a bit of research and future down the line i will buy a more purpose full diff such as gripper. But for now I will probably look into what your suggesting
