JC5-145 Ratios
neil a
Does anyone have a list of the jc5-140 box ratios please ? I've had a look and can't find anything other than it was fitted to the 1.5dci clios.
Yanoo
  Clio Williams
Re: JC5-140 Ratios
JC5-140:
I. 3.727
II. 2.047
III. 1.321
IV. .971
V. .756
FD 3.294
The Boosh!
ClioSport Admin
  Elise, Duster
Re: JC5-140 Ratios
1st to 5th + final drive, revers gear + tachometer.
JC5-140
11/41
21/43
28/37
35/34
41/31
17/56
11/39
neil a
Re: JC5-140 Ratios
Thanks alot going by those ratios and the low final drive , the speeds are way too low for what i need topping out at 102mph.
Yanoo
  Clio Williams
Re: JC5-140 Ratios
Are you sure? Its FD is very long (it is the longest FD in the JC5 range). It's good for a diesel engine but not for a petrol engine IMO (except if you would like to get good mpg).
neil a
Re: JC5-140 Ratios
Sorry Yanoo I have just re read the PM and it is actualy a JC5-145 box not a 140 do you have the ratios for this box.
It has also been fitted with a 4.5 final drive, thats how i got the lower speed when working out the 140 box as with the standard FD it will do 140mph.
neil a
Re: JC5-140 Ratios
Do you know what the gearing in them is ment to be like to as in is it fairly close ratio? I can't find the ratios for the 145 anywhere but have found a place listing that box so have emailed them.
