yes i know i but i didnt want to use it as its rather crude for filling upAt the front of the gearbox, where the power steering pipe is there is a big black plastic wingnut.
You wouldn't know when to stop if you dripped it in the top though!
You have to keep it level and then when it starts coming out the hole that you use to fill it then its correct. Just see how much is left in the bottle afterwards.
Sorry I don't follow, so when you remove the filler plug a little comes out straight away? That to me says you've not lost any/a tiny tiny amount. I take it you've got a leak around the selector?
Ah right. Yeah check the sump and rocker cover gasket as well.
