JMS RS2 inlet installation help on Clio 172 cup
  dan's cast offs.
not as good as a standard manifold that's for sure. never done a back to back test though but they just don't gove good results and seen them on a few different models as well.
1985michael182
So it was pretty straight forward but definatly needs mapping. Feels very flat pre 5000rpm
1985michael182
Iv 4 layers of gorilla tape over those 2 holes before the black tape so it's not going anywhere. There's no pressure on them when the TB is open. But I get what you mean. Just a test fit really, but it all runs ok no dramas so ill make 2 ali plates to bond on and rip the carbon canister and acoustic valve out then clean the bay up and finish things off
1985michael182
Not as yet. It all needs to come back off to properly block the 2 holes drilled into the plenum so I'll take a load of pictures and do a little write up. Took an hour too fit including the pms coil relocation plate and the pms breather plate. Pretty straight forward.
