jumping out of gear and funky steering issue
Car  cliosport 182
Clio 182, started popping out of 1st gear when wheels start spinning, I have powerflex lower dogbone mount fitted And I changed upper gearbox mount couple months ago, tho it wasn't a genuine renualt one, anybody have any ideas on what could be up?2nd got bit of a steering issue wheels seem to follow tracks in the road, and there's a bit of a clunking noise over the odd bump, I've had 2 mechanics/Mot inspectors look at my car And both say the car is pritty tight and solid And there's no signs of any play in anything, I've swapped wheels frm front to back, had tracking checked tho not laser checked (old skool way) any help again cheers
On full lock either way, going forward or reverse, the car sort of skips over itself, did a little search And come across.... could be driveshaft or top mount, would the driveshaft cause a knocking noise over bumps and cause the tramlining effect on roads with grooves worn in.Looked at top mount on passangerside where nut goes ontop And that area is rusty, is that a sign of anything or just where water been sat?
