just a few problems i would like help with (tracking, locking, traction control,door)
  renault clio 172
i have a 2003 clio 172 and here are the problems i need help with and suggestions:
tracking: my rear passanger wheel has excessive wear on the outer 3rd of it all i can see from looking underneath it that the hollow section tube that is parralel with the doors outside seem to sit at slightly different angles, is this likely to be just a case of tracking needs doing or a worn bush?
locking: when i lock the door with the key for it fully arms the alarm leaving a constant buzz sound that doesnt stop, other than that its fine to unlock with the keyfob and i have to lock it with the inside button what could this be?
traction control: when i press the traction control button it dosnt apear to do anything on the dash even if i press it twice or hold it in
door open light: it stays on even when everythings shut the previous owner did however damage the bonnet when it wouldnt shut but the catch is fine and the trigger/ sensor that tells the ecu its closed
all info will be muchly aprechiated regards dan.
