Just Fitted 205/45/16 On My Turninis (hmmm - Help)
  RenaultSport clio 172 mk2
Ive just fitted 205/45/16's on my anthracite turinis - however i cant help but think this is the wrong choice, there seems to be alot more roll in the car, alot more bouncy castle like - im running 32 front and 31 rear... should i be on any different ??
feels as tho the rear is'nt part of the car when i corner lightly - kind of side weinds, hmmm
tyres are michelins, unsure of the model tho - will check
so would it be ok to run say:
35 front
32 rear
or even 1 psi up on that ??
EVOgone
  Pink Cup Racer
33/31 when they get to 30 cold in the front they handle poorly...they are very pressure sensitive. Get it right they are great.!
suspesion is just standard cup.
so 33/31 sounds good :) will fettle it now
was just abit worried about putting 205's on - i did not know if they were ok to go on, saw that craig on here has them, but then was wondering if he just put them on unknowing if they were to fit - as the usual tyres on the rims are 195
cheers
  No more clio's for me!
So your fitted tyres are 10mm wider than the rim? Can you do that, won't they just come off when you go round corners hard? :eek:
no..........but normally going wider to 205 u normally decrease them to 40.
but should nt make that much difference .
  172 Cup
to be honest they should be fine. i would play with the pressure and see how you get on. in theory 205 should give you more grip.
Paul
  320d
They're totally fine 182's come with 205/45 tyres as standard whereas the 172 came with 195/45 both on the same rim diameter and width
cheers people,
just been scanning the site and noticed the spec on the 182 - this car has 205/45/16 - different rim, but the trophy rim is the same - so obviously my tyres cant be bad lol
gona have a play with the pressures
