CLIO-Si
1.6Si + 182
i still cant find any info about what would cause my engine to drop the aux-belt into the inside drivers arch and give me sparks from the pulleys side on hitting arch/chassis
or
why my dogbone is sitting squint,
also my dogbone is a ph1 solidplastic body instead of aluminium body which is on my 8v of the same age,also where it bolts to chassis its got a 70mm square rubber inch thick thing which has a thread section in the centre and a wee inch metal circle around the thread.
i have noticed today with the car on stands that the steering is basically moving my engine side to side when on over half turns, this will be causing the belt side of engine to get pushed into the arch but why??
also been reading that many d/s are different sizes,lenths and once again the shafts are from a clio same age/size just 8v
anyone?atall?
thanks.
or
anyone?atall?
thanks.
