K&N filter re-located in front of battery with cold air feeds from under car got the following results:
Start Speed 0.0mph
mph s g ft hp
10.0 0.88 0.53 6 35
20.0 1.70 0.56 24 74
30.0 2.49 0.59 53 120
40.0 3.38 0.43 99 121
50.0 4.92 0.35 199 126
60.0 6.31 0.31 312 142
70.0 8.43 0.23 514 134
Pk Power: 69.2mph 8.26s 497ft 151hp
Peak G: 33.2mph 2.72s 64ft 0.61g
Start Speed 0.0mph
mph s g ft hp
10.0 0.92 0.51 6 34
20.0 1.78 0.53 25 71
30.0 2.60 0.55 55 112
40.0 3.43 0.48 98 131
50.0 4.90 0.34 194 123
60.0 6.20 0.33 299 149
Pk Power: 61.1mph 6.35s 313ft 154hp
Peak G: 36.6mph 3.11s 80ft 0.59g
I then moved it, and attached it to the elbow coming off the throttle body, and this happened:
Start Speed 0.0mph
mph s g ft hp
10.0 1.01 0.56 6 36
20.0 1.83 0.55 24 73
30.0 2.67 0.51 55 103
40.0 3.82 0.16 116 50
50.0 5.28 0.31 211 115
60.0 6.77 0.28 332 128
Pk Power: 62.0mph 7.07s 359ft 141hp
Peak G: 12.6mph 1.21s 9ft 0.58g
Start Speed 0.0mph
mph s g ft hp
10.0 0.98 0.58 6 38
20.0 1.78 0.59 23 78
30.0 2.76 0.48 59 99
40.0 4.05 0.28 127 80
50.0 5.38 0.33 216 121
60.0 6.86 0.28 335 131
Pk Power: 60.4mph 6.92s 341ft 137hp
Peak G: 21.1mph 1.86s 25ft 0.59g
....oh dear. If you do put one on, make sure you buy some hosing with it and locate it away from the heat of the engine bay. Ive switched to using a Pipercross Viper now, but the relocated K&N worked as well and sounded better.
Although, as Neil says, for pure performance, a panel filter and an RSport ECU are the best bet.
