foam filters are quieter than cotton gauze.....
id go for Green over the 2 basically because of there construction, because K&N use a kind of glue around the edge, this seeps a bit into the filters edges and loses you some surface area....
Green dont use this and you get maximum surface area, there also usually cheaper
as said before though, both will be very similar
