Key battery
  Golf GTD Mk7
Where can i get hold of a key fob battery for a mk1 ph1 172? Its slightly bigger than the one in the 182 for some reason.
MRBILLYUK
  FF Jeden Osiem Dwa
Iirc the battery in a 1*2 keyfob is a CR3032 . You sure your battery is different ?
Look on the battery and it will have a number . Go to Halfords , Asda , Tesco ...... etc and look for one with that number on . You need that number , it's not something you can just guess at .
  Skoda Fabia vRS
it wont be a '3032' i dont think such a battery exists, a common fob battery is a 2032 but no Renault uses this
if its not the tiny one, a 1220, it will be a 2016 which you can pick up at the dealers or most supermarkets
