Clio 182 Trophy. No. 189
.........Key fob or the ignition ring for my Clio 172 Mk2 (2002 - 02)
Situation = I ony have 1 keyfob and the button for the central locking broke off and was resoldered. Before this was soldered and over the last few months I am having problems starting the car. The immobiliser light often remains on after the key is inserted.
Is my best option to obtain a new key first or replace the ignition ring? The key does sometimes work but it is very tempramental. At work I leave the key in the ignition as it seems to work fine if it is not in my pocket all day. When I take the key apart / remove battery this sometimes works. There does not appear to be any internal damage but maybe solder / glue has damaged the circuit board?
Any thoughts greatly appreciated!
