Keyboard, back2front?
Car  CLIOpatra, L22EE W™
Did a clean install of XP about 2 weeks ago, noticed that some of the keys on my keyboard are all over the place.
Example the '@' key is actually obtained by pressing 'SHIFT & 2' instead of pressing the @ key on the keyboard.
Another example, if I was the " key, I need to press 'SHIFT & the @ key' on my keyboard.
It's driving me mad. Looked in the keyboard section under control panel, but just can't get it sorted.
HELP! :mad:
change the language to english UK, in the controll panel. its in accessories i think.
or just type keyboard language into help.
I haven't used windows for a hwile now but what it will be is you've set your keyboard up as a US keyboard which has the @ and the " in differet places. try to find the part in control panel and change it to a UK keyboard.
Should be reet.
Go into Regional and Language Options, within control panel
Change everything from United States to United Kingdom
The most important bit I think is in the Languages tab, then Details. make sure you delete US after you add UK :)
Or use the shortcut "Alt-Shift" or "CTRL-Shift". I always catch them at work when using Alt-tab and switch the keyboard layout.
