Ok so went to the car this morning and the car didn't open. Tried the other fob and that didn't work. Used the hidden fob key and the car is completely flat.
Tried jumping using the missus car +ve to +ve then -ve to ground. Nothing after 3 mins then nothing after her car had been started for a few mins. Disconnected and tried again, then finally get a spark at ground and ignition comes to life.
Same again, waited a few minutes then start her car. Held the revs on that for a few mins then tried the usual "hold brake and press start button" all the usual ignition sounds and lights come on but the car doesn't even attempt to start.
Long story short and around 30 minutes connected I can get it so the ignition is on but it won't attempt to turn over. Tried all combinations - inserting the fob, removing it etc.
Luckily it removed the steering lock so I can be towed if necessary as I don't have home start. However, it's left the lights on and I can't turn them off, so it'll be completely flat again shortly.
It's a bit unusual as the battery is a brand new Duracell fitted a month before I bought it a few weeks ago. I only drove 30ish miles last night at 10pm so it's not like it's been sat for a while.
Tried searching the forum but no similar issues. I may try bump starting but don't know how it would react being keyless.
Any ideas?
Any ideas?
