Kill Switch Resister urgent!!
donnylad
just copying my facebook post here as I am kind of desperate
Kill switch resister?
Wiring in my kill switch and it has a 3ohm 11 watt resister that goes to earth. It has snapped and I need one by Sunday, any idea where I can pick one up from tomorrow? closer to yorkshire the better
Alternatively what would happen if I ran the kill switch without one? It will get used once in scrutineering.
Any help appreciated!
If you run without it the alternator will spike when you turn the car off, and if you're lucky do nothing bar spark across the contacts. If unlucky kill the regulator in the alternator. If really unlucky it'll fry the ecu or whatever is the weakest like.
You might be able to grab one from RS and have it delivered tommorow - I use the ally cased wire wound ones.
Failing that I've probably got a few but I'm not up at the workshop till tommorow night.
